FIAT 126 BIS (1987-1999)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU | Go to group |
10000 - MOTOR | Go to sub group |
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU | Go to sub group |
101 - BLOK VE SİLİNDİR KAPAĞI | Go to group |
10101 - BLOK VE SİLİNDİR KAPAĞI | Go to sub group |
10102 - KARTER VE BLOK KAPAKLARI | Go to sub group |
10103 - KRANK MİLİ VE VOLAN | Go to sub group |
10105 - BİYELLER VE PİSTONLAR | Go to sub group |
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI | Go to sub group |
10107 - SÜBAP ZAMANLAMA MEKANİZMASI | Go to sub group |
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) | Go to sub group |
102 - ENJEKSIYON SISTEMI | Go to group |
10200 - YAKIT DEPOSU | Go to sub group |
10201 - YAKIT DEPOSU BORULARI | Go to sub group |
10202 - UREA DEPOSU | Go to sub group |
10204 - TABAN ALTI UREA BORUSU | Go to sub group |
10222 - GAZ PEDALI KUMANDASI | Go to sub group |
10223 - HAVA FILITRESI VE BORULARI | Go to sub group |
10255 - EMME MANIFOLDU | Go to sub group |
10258 - EGZOZ BORUSU | Go to sub group |
10259 - EGZOZ EMISYON KONTROL SISTEMI | Go to sub group |
103 - YAGLAMA SISTEMI | Go to group |
10301 - YAGLAMA SISTEMI | Go to sub group |
104 - SOGUTMA SISTEMI | Go to group |
10401 - RADYATOR VE BORULAR | Go to sub group |
10402 - SU POMPASI VE BORULARI | Go to sub group |
10409 - VANTILATOR VE KUMANDASI | Go to sub group |
181 - DEBRIYAJ SISTEMI | Go to group |
18101 - DEBRIYAJ BALATA KUMANDASI | Go to sub group |
18109 - DEBRIYAJ SISTEMI | Go to sub group |
212 - VITES KUTUSU | Go to group |
21200 - VITES KUTUSU | Go to sub group |
21207 - KUTU VE KAPAKLAR | Go to sub group |
21215 - VITES DISLILERI | Go to sub group |
21219 - VITES KUTUSU IC KUMANDALARI | Go to sub group |
21220 - DIFRANSIYEL DISLISI | Go to sub group |
21221 - VITES KUTUSU DIS KUMANDALARI | Go to sub group |
21233 - KM SINYAL VE KUMANDASI | Go to sub group |
274 - AKS VE AKS MILLERI | Go to group |
27402 - AKSLAR | Go to sub group |
331 - FREN SISTEMI | Go to group |
33101 - FREN PEDEAL KUMANDASI | Go to sub group |
33102 - HIDROLIK FREN KUMANDASI | Go to sub group |
33117 - ON TEKERLEK FREN GRUBU | Go to sub group |
33125 - ARKA TEKERLEK FRENI | Go to sub group |
33135 - EL FREN KUMANDASI | Go to sub group |
412 - DIREKSIYON SISTEMI | Go to group |
41201 - DIREKSIYON KUMANDASI | Go to sub group |
41210 - DIREKSIYON KUMANDA CUBUKLARI | Go to sub group |
443 - TEKERLEK VE SUSPANSIYON SISTEMI | Go to group |
44301 - ON SUSPANSIYON | Go to sub group |
44305 - ARKA SUSPANSIYON | Go to sub group |
44314 - ON AKS | Go to sub group |
44316 - TEKERLEKLER | Go to sub group |
501 - KLİMA | Go to group |
50101 - KALORIFER TESISATI VE VANTILATORU | Go to sub group |
50102 - KALORIFER PARCALARI | Go to sub group |
551 - MOTOR ATESLEME SISTEMI | Go to group |
55101 - MOTOR ATESLEME SISTEMI | Go to sub group |
55102 - ATESLEME UNITESI | Go to sub group |
552 - MARS SISTEMI | Go to group |
55201 - MARS SISTEMI | Go to sub group |
55202 - KONTAK ANAHTARI | Go to sub group |
553 - SARJ SISTEMI | Go to group |
55300 - AKU | Go to sub group |
55301 - ALTERNATOR AND MOUNTING | Go to sub group |
554 - AYDINLATMA SISTEMI | Go to group |
55401 - DIS AYDINLATMA | Go to sub group |
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI | Go to group |
55501 - SINYAL UNITESI VE ELEMANLARI | Go to sub group |
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER | Go to sub group |
55503 - KUMANDA DUGMELERI | Go to sub group |
55510 - GOSTERGELER | Go to sub group |
55514 - ON CAM VE FAR YIKAMA | Go to sub group |
55523 - ON BOLUM KABLO TESISATI | Go to sub group |
55525 - ARKA BOLUM KABLO TESISATI | Go to sub group |
55527 - KABLO TESISATI TESPIT ELEMANLARI | Go to sub group |
681 - AVADANLIK | Go to group |
68101 - AVADANLIK | Go to sub group |
700 - KAROSERI VE KAPORTA PARCALARI | Go to group |
70002 - GOVDE,ON ISKELET | Go to sub group |
70003 - GOVDE,ORTA ISKELET | Go to sub group |
70006 - TABAN SACI | Go to sub group |
70018 - GOVDE,ON KAPLAMALAR | Go to sub group |
70019 - GOVDE,ORTA KAPLAMALAR | Go to sub group |
70020 - GOVDE,ARKA KAPLAMALAR | Go to sub group |
701 - PANELLER VE CAMLAR | Go to group |
70129 - ON KAPILAR | Go to sub group |
70133 - ON KAPI IC PANELI | Go to sub group |
70148 - BESINCI KAPI | Go to sub group |
70155 - ON CAM | Go to sub group |
70156 - YAN CAMLAR | Go to sub group |
70160 - BAGAJ BOSLUGU KAPAGI | Go to sub group |
705 - IC TRIM PARCALARI | Go to group |
70502 - ON GOGUS VE PARCALARI | Go to sub group |
70504 - ON GOGUS (KONSOL) | Go to sub group |
70521 - HALILAR | Go to sub group |
70522 - IZALASYON VE SUNGERLER | Go to sub group |
70523 - IC KAPLAMALAR | Go to sub group |
70524 - IC PANEL AKSESUARLARI | Go to sub group |
70525 - AKSESUARLAR VE DIGER ELEMANLAR | Go to sub group |
70527 - EMNIYET KEMERLERI | Go to sub group |
70528 - STEPNE SISTEMI | Go to sub group |
706 - KOLTUKLAR | Go to group |
70601 - ON KOLTUKLAR | Go to sub group |
70605 - ON KOLTUK KIZAKLARI | Go to sub group |
70606 - ON KOLTUK KILIFLARI | Go to sub group |
70613 - REAR SEAT | Go to sub group |
70615 - REAR SEAT LINING | Go to sub group |
707 - DIS TRIM PARCALARI | Go to group |
70712 - DIS TRIM PARCALARI | Go to sub group |
70715 - LOGOLAR, YAZILAR | Go to sub group |
70723 - SİPERLER | Go to sub group |
70726 - ON TAMPON | Go to sub group |
70727 - ARKA TAMPON | Go to sub group |
70732 - DIS TRIM PARCALARI | Go to sub group |
70740 - DIS DIKIZ AYNASI | Go to sub group |
70743 - DOKUMANTASYON | Go to sub group |
703 CARB."BIS SS.UP" | 126.520.4.1 | Go to catalogue |
703 CARB."BIS" | 126.520.4.0 | Go to catalogue |
703 CARB.DAV-15 "BIS" | 126.527.4.0 | Go to catalogue |
Modification | Description | Activations |
6528 | YENI AKU VE MARS MOTORU KABLOLARI | DAT 15/05/2003 |
8946 | GRI RENKLI YENI IC KUMAS KAPLAMALAR ADAPTE EDILMISTIR. | DAT 15/09/1987 |
8980 | WAY -ASSAUTO AMORTISORLER ADAPTE EDILMISTIR. | DAT 15/11/1987 |
9168 | YENI WEBER KARBURATOR | DAT 15/07/1988 |
9171 | YENI MOTOR SOGUTMA ELEKTROFANI VE REZISTORU | VET 1718951 |
9398 | FAR AYAR TERTIBATI ADAPTE EDILMISTIR. | DAT 15/09/1989 |
9457 | YENI EGZOZ SUSTURUCUSU VE ARTIK SUSTURUCU UZERINE KAYNAKLANMAYAN YENI YENI TESPIT BRAKETLERI | VET 1866332 |
9476 | YENI DIS YAN DIKIZ AYNASI TESPIT DELIKLERI TAPALARI ADAPTE EDILMISTIR | DAT 15/07/1989 |
9587 | KOLTUK BASLIKLI VE AYARLANABILIR YENI ON KOLTUKLAR | DAT 15/03/1990 |
9678 | YENI DISLI VE SENKROMENCLER ADAPTE EDILMISTIR. | MOT 3165930 |
9861 | YENİ MOTOR VOLANI | MOT 6441801 |
11237 | ADOPTION NEW SPECIAL SCREW FOR FLYWHEEL FASTENING | DAT 15/05/2006 |
