FIAT PANDA CLASSIC (2012-2012)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU | Go to group |
10000 - MOTOR | Go to sub group |
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU | Go to sub group |
10003 - MOTOR SÜSPANSİYONU | Go to sub group |
101 - BLOK VE SİLİNDİR KAPAĞI | Go to group |
10101 - BLOK VE SİLİNDİR KAPAĞI | Go to sub group |
10102 - KARTER VE BLOK KAPAKLARI | Go to sub group |
10103 - KRANK MİLİ VE VOLAN | Go to sub group |
10105 - BİYELLER VE PİSTONLAR | Go to sub group |
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI | Go to sub group |
10107 - SÜBAP ZAMANLAMA MEKANİZMASI | Go to sub group |
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) | Go to sub group |
102 - ENJEKSIYON SISTEMI | Go to group |
10200 - YAKIT DEPOSU | Go to sub group |
10201 - YAKIT DEPOSU BORULARI | Go to sub group |
10203 - YAKIT BORULARI TESPIT PARCALARI | Go to sub group |
10222 - GAZ PEDALI KUMANDASI | Go to sub group |
10223 - HAVA FILITRESI VE BORULARI | Go to sub group |
10225 - ENJEKSIYON TESISATI | Go to sub group |
10226 - ENJEKSİYON BESLEME | Go to sub group |
10247 - ISI MUHAFAZA VE BORULAR | Go to sub group |
10252 - ASIRI BESLENME SISTEMI | Go to sub group |
10255 - EMME MANIFOLDU | Go to sub group |
10256 - EGZOZ MANIFOLDU | Go to sub group |
10258 - EGZOZ BORUSU | Go to sub group |
10259 - EGZOZ EMISYON KONTROL SISTEMI | Go to sub group |
10260 - HAVA KIRLILIK ONLEME SISTEMI | Go to sub group |
103 - YAGLAMA SISTEMI | Go to group |
10301 - YAGLAMA SISTEMI | Go to sub group |
104 - SOGUTMA SISTEMI | Go to group |
10401 - RADYATOR VE BORULAR | Go to sub group |
10402 - SU POMPASI VE BORULARI | Go to sub group |
10409 - VANTILATOR VE KUMANDASI | Go to sub group |
181 - DEBRIYAJ SISTEMI | Go to group |
18101 - DEBRIYAJ BALATA KUMANDASI | Go to sub group |
18103 - HIDROLIK DEBRIYAJ KUMANDASI | Go to sub group |
18109 - DEBRIYAJ SISTEMI | Go to sub group |
212 - VITES KUTUSU | Go to group |
21200 - VITES KUTUSU | Go to sub group |
21207 - KUTU VE KAPAKLAR | Go to sub group |
21215 - VITES DISLILERI | Go to sub group |
21219 - VITES KUTUSU IC KUMANDALARI | Go to sub group |
21220 - DIFRANSIYEL DISLISI | Go to sub group |
21221 - VITES KUTUSU DIS KUMANDALARI | Go to sub group |
21233 - KM SINYAL VE KUMANDASI | Go to sub group |
243 - MILLER VE MAFSALLAR | Go to group |
24301 - SAFT | Go to sub group |
274 - AKS VE AKS MILLERI | Go to group |
27402 - AKSLAR | Go to sub group |
27404 - ARKA KÖPRÜ DİFERANSİYEL YARIM AKSLARI (4X4) | Go to sub group |
27408 - DİŞLİ KUTUSU VE ARKA KÖPRÜ DİFERANSİYELİ (4X4) | Go to sub group |
331 - FREN SISTEMI | Go to group |
33101 - FREN PEDEAL KUMANDASI | Go to sub group |
33102 - HIDROLIK FREN KUMANDASI | Go to sub group |
33109 - FREN BASINC TESISATI | Go to sub group |
33117 - ON TEKERLEK FREN GRUBU | Go to sub group |
33125 - ARKA TEKERLEK FRENI | Go to sub group |
33135 - EL FREN KUMANDASI | Go to sub group |
33136 - FREN TESISATI TESPIT ELEMANLARI | Go to sub group |
381 - MEKANIK AKSAM MUHAFAZALARI | Go to group |
38115 - SASI MUHAFAZASI | Go to sub group |
412 - DIREKSIYON SISTEMI | Go to group |
41201 - DIREKSIYON KUMANDASI | Go to sub group |
443 - TEKERLEK VE SUSPANSIYON SISTEMI | Go to group |
44301 - ON SUSPANSIYON | Go to sub group |
44305 - ARKA SUSPANSIYON | Go to sub group |
44316 - TEKERLEKLER | Go to sub group |
44321 - ARKA AKS PARCASI | Go to sub group |
501 - KLİMA | Go to group |
50101 - KALORIFER TESISATI VE VANTILATORU | Go to sub group |
50104 - KLIMA KOMPRESORU | Go to sub group |
551 - MOTOR ATESLEME SISTEMI | Go to group |
55101 - MOTOR ATESLEME SISTEMI | Go to sub group |
55102 - ATESLEME UNITESI | Go to sub group |
552 - MARS SISTEMI | Go to group |
55201 - MARS SISTEMI | Go to sub group |
55202 - KONTAK ANAHTARI | Go to sub group |
553 - SARJ SISTEMI | Go to group |
55300 - AKU | Go to sub group |
55301 - ALTERNATOR AND MOUNTING | Go to sub group |
554 - AYDINLATMA SISTEMI | Go to group |
55401 - DIS AYDINLATMA | Go to sub group |
55402 - IC AYDINLATMA | Go to sub group |
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI | Go to group |
55501 - SINYAL UNITESI VE ELEMANLARI | Go to sub group |
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER | Go to sub group |
55503 - KUMANDA DUGMELERI | Go to sub group |
55508 - HAVA YASTIGI TERTIBATI | Go to sub group |
55510 - GOSTERGELER | Go to sub group |
55514 - ON CAM VE FAR YIKAMA | Go to sub group |
55521 - RADYO SISTEMI | Go to sub group |
55523 - ON BOLUM KABLO TESISATI | Go to sub group |
55524 - ORTA BOLUM KABLO TESISATI | Go to sub group |
55525 - ARKA BOLUM KABLO TESISATI | Go to sub group |
55526 - ILAVE KABLO TESISATI | Go to sub group |
55527 - KABLO TESISATI TESPIT ELEMANLARI | Go to sub group |
681 - AVADANLIK | Go to group |
68101 - AVADANLIK | Go to sub group |
700 - KAROSERI VE KAPORTA PARCALARI | Go to group |
70001 - GOVDE | Go to sub group |
70002 - GOVDE,ON ISKELET | Go to sub group |
70003 - GOVDE,ORTA ISKELET | Go to sub group |
70004 - GOVDE ,ARKA ISKELET | Go to sub group |
70006 - TABAN SACI | Go to sub group |
70018 - GOVDE,ON KAPLAMALAR | Go to sub group |
70019 - GOVDE,ORTA KAPLAMALAR | Go to sub group |
70020 - GOVDE,ARKA KAPLAMALAR | Go to sub group |
701 - PANELLER VE CAMLAR | Go to group |
70101 - MOTOR KAPUTU | Go to sub group |
70122 - TAVAN PENCERESI | Go to sub group |
70129 - ON KAPILAR | Go to sub group |
70133 - ON KAPI IC PANELI | Go to sub group |
70134 - AKSESUARLAR,ON KAPI IC PANELI ICIN | Go to sub group |
70136 - ARKA KAPILAR | Go to sub group |
70140 - ARKA KAPI IC PANELI | Go to sub group |
70141 - AKSESUARLAR,ARKA KAPI IC PANELI ICIN | Go to sub group |
70148 - BESINCI KAPI | Go to sub group |
70155 - ON CAM | Go to sub group |
70156 - YAN CAMLAR | Go to sub group |
70169 - ARA BOLME | Go to sub group |
705 - IC TRIM PARCALARI | Go to group |
70502 - ON GOGUS VE PARCALARI | Go to sub group |
70504 - ON GOGUS (KONSOL) | Go to sub group |
70521 - HALILAR | Go to sub group |
70522 - IZALASYON VE SUNGERLER | Go to sub group |
70523 - IC KAPLAMALAR | Go to sub group |
70525 - AKSESUARLAR VE DIGER ELEMANLAR | Go to sub group |
70526 - BAGAJ IC KAPLAMALARI | Go to sub group |
70527 - EMNIYET KEMERLERI | Go to sub group |
706 - KOLTUKLAR | Go to group |
70601 - ON KOLTUKLAR | Go to sub group |
70605 - ON KOLTUK KIZAKLARI | Go to sub group |
70606 - ON KOLTUK KILIFLARI | Go to sub group |
70613 - REAR SEAT | Go to sub group |
70615 - REAR SEAT LINING | Go to sub group |
707 - DIS TRIM PARCALARI | Go to group |
70712 - DIS TRIM PARCALARI | Go to sub group |
70715 - LOGOLAR, YAZILAR | Go to sub group |
70717 - HAVA DAGITICILAR VE CESITLI KAPAKLAR | Go to sub group |
70722 - RADYATOR PANJURU | Go to sub group |
70723 - SİPERLER | Go to sub group |
70726 - ON TAMPON | Go to sub group |
70727 - ARKA TAMPON | Go to sub group |
70732 - DIS TRIM PARCALARI | Go to sub group |
70740 - DIS DIKIZ AYNASI | Go to sub group |
70743 - DOKUMANTASYON | Go to sub group |
70750 - UYARI VE TAVSİYE ETİKETLERİ | Go to sub group |
2V.1.2 BZ. E5 L1-ACTIVE GD.5M.RU/I BASIC | 1690JK451870 | Go to catalogue |
2V.1.2 BZ. E5 L1-ACTIVE GPL GS.5M-I/CEB. | 1690JH401000 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M. BAS DANIM | 1690KK401000 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M. N.EU.BASIC | 1690JK401830 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M. TR BASIC | 1690JK401810 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M.CILE.BASIC | 1690JK401550 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M.I/CE BASIC | 1690JK401000 | Go to catalogue |
2V.1.2 BZ.E5 L1-ACTIVE GS.5M.MEXIC.BASIC | 1690JK401470 | Go to catalogue |
2V.1.2 BZ.E5 L9-CLIMBING4X4 GS.5M-I/CBAS | 1690FJ401000 | Go to catalogue |
2V.1.2 BZ.E5 L9-CLIMBING4X4 GS.5M-NEUBAS | 1690FJ401830 | Go to catalogue |
2V.1.3JTD E5 L1-ACTIVE 5P.GS.5M.-I/CEBAS | 1690JP401000 | Go to catalogue |
2V.1.3JTD E5 L9-CLIMBING 4X4 GS.5M-I/CBA | 1690FP401000 | Go to catalogue |
2V.1.4 BZ.E5 L1-NAT. POWER 5P.GS.BASIC | 1690JN401000 | Go to catalogue |
PAN. 1.2 BZ. E5 -L1 ACT. GS.5M-I/CEM.Y. | 2712RJ401000 | Go to catalogue |
PAN. 1.2 JTD. E5 -L1 ACT. GS.5M-I/CE M.Y | 2712RP401000 | Go to catalogue |
VAN 1.3 DPF E5 -L1ACTIV GS.5M.-I/CE M.Y. | 2710XP401000 | Go to catalogue |
VAN.1.2 BZ. E5 -L1ACTIVE GS.5M-I/CEM.Y. | 2710XJ401000 | Go to catalogue |
VAN.1.2 BZ.E5 L5-TREK. 4X4 GS.5M-I/C M.Y | 2710YJ401000 | Go to catalogue |
VAN.1.3JTD E5 L5-TREKK.4 X4 GS.5M-I/CM.Y | 2710YP401000 | Go to catalogue |
Modification | Description | Activations |
13000 | TO MANAGE RECONDITIONED VEHICLES | DAT 30/06/2012 |
15362 | YENİ GARANTİ KİTAPÇIĞI | DAT 20/04/2012 |
15404 | ATMOSFERİK KONDİSYONLARIN NEDEN OLDUĞU YAŞLANMA ZALTILMIŞTIR | DAT 09/11/2012 |
15561 | YENİ ARKA FREN KAMPANALARI TAKILMIŞTIR | DAT 09/12/2011 |
15644 | Egzoz manifoldu/turbokompresör yeni contası | DAT 17/02/2012 |
15681 | Yeni ünite devreye girmiştir | DAT 20/02/2012 |
15691 | YENİ II VİTES HIZ ORANI | DAT 19/03/2012 |
15732 | Yeni vites kumanda parçaları | DAT 31/01/2012 |
15748 | Yeni direksiyon kutusu | DAT 02/02/2012 |
15761 | Yeni software | DAT 23/03/2012 |
15785 | Yeni metan deposu ve yeni elektrovalfler | DAT 08/03/2012 |
15887 | Yeni emme manifoldu | DAT 16/05/2012 |
15935 | Yeni kavrama kiti | DAT 18/06/2010 |
15956 | Yeni su pompası ve yeni conta | DAT 19/09/2012 |
15990 | Vitese takmayı iyileştirmek için yeni vites kutusu C514 step 1 | DAT 07/07/2012 |
15991 | Vitese takmayı iyileştirmek için yeni vites kutusu C514 step 2 | DAT 14/09/2012 |
16092 | C514 vites manevra kabiliyeti iyileştirilmiştir | DAT 17/07/2012 |
16114 | Hacim ve kaynak değişikliği nedeniyle yeni şase saçları adapte edilmiştir | DAT 02/01/2012 |
16118 | Yeni orta ve arka egzoz borusu | DAT 11/04/2012 |
16161 | Yeni emme manifoldu | DAT 13/11/2012 |
16166 | Standardizasyon için yeni ön taban | DAT 02/01/2012 |
16167 | Yeni turbokompresör devreye girmiştir | DAT 11/10/2012 |
16169 | Şase üzerindeki egzoz borusuna yeni tespit kancaları takılmıştır | DAT 10/07/2012 |
16278 | Yeni ingilizce garanti kitapçığı | DAT 23/03/2012 |
16510 | New steering control | DAT 16/04/2012 |
16530 | New servicing booklets for update | DAT 27/04/2012 |
