FIAT STRADA 2011 (2011-2014)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU Go to group
10000 - MOTOR Go to sub group
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU Go to sub group
10003 - MOTOR SÜSPANSİYONU Go to sub group
101 - BLOK VE SİLİNDİR KAPAĞI Go to group
10101 - BLOK VE SİLİNDİR KAPAĞI Go to sub group
10102 - KARTER VE BLOK KAPAKLARI Go to sub group
10103 - KRANK MİLİ VE VOLAN Go to sub group
10105 - BİYELLER VE PİSTONLAR Go to sub group
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI Go to sub group
10107 - SÜBAP ZAMANLAMA MEKANİZMASI Go to sub group
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) Go to sub group
102 - ENJEKSIYON SISTEMI Go to group
10200 - YAKIT DEPOSU Go to sub group
10201 - YAKIT DEPOSU BORULARI Go to sub group
10222 - GAZ PEDALI KUMANDASI Go to sub group
10223 - HAVA FILITRESI VE BORULARI Go to sub group
10225 - ENJEKSIYON TESISATI Go to sub group
10226 - ENJEKSİYON BESLEME Go to sub group
10247 - ISI MUHAFAZA VE BORULAR Go to sub group
10252 - ASIRI BESLENME SISTEMI Go to sub group
10255 - EMME MANIFOLDU Go to sub group
10256 - EGZOZ MANIFOLDU Go to sub group
10258 - EGZOZ BORUSU Go to sub group
10259 - EGZOZ EMISYON KONTROL SISTEMI Go to sub group
10260 - HAVA KIRLILIK ONLEME SISTEMI Go to sub group
103 - YAGLAMA SISTEMI Go to group
10301 - YAGLAMA SISTEMI Go to sub group
104 - SOGUTMA SISTEMI Go to group
10401 - RADYATOR VE BORULAR Go to sub group
10402 - SU POMPASI VE BORULARI Go to sub group
10409 - VANTILATOR VE KUMANDASI Go to sub group
181 - DEBRIYAJ SISTEMI Go to group
18103 - HIDROLIK DEBRIYAJ KUMANDASI Go to sub group
18109 - DEBRIYAJ SISTEMI Go to sub group
212 - VITES KUTUSU Go to group
21200 - VITES KUTUSU Go to sub group
21207 - KUTU VE KAPAKLAR Go to sub group
21215 - VITES DISLILERI Go to sub group
21219 - VITES KUTUSU IC KUMANDALARI Go to sub group
21220 - DIFRANSIYEL DISLISI Go to sub group
21221 - VITES KUTUSU DIS KUMANDALARI Go to sub group
21233 - KM SINYAL VE KUMANDASI Go to sub group
274 - AKS VE AKS MILLERI Go to group
27400 - AKS TASIYICI Go to sub group
27402 - AKSLAR Go to sub group
331 - FREN SISTEMI Go to group
33101 - FREN PEDEAL KUMANDASI Go to sub group
33102 - HIDROLIK FREN KUMANDASI Go to sub group
33109 - FREN BASINC TESISATI Go to sub group
33117 - ON TEKERLEK FREN GRUBU Go to sub group
33125 - ARKA TEKERLEK FRENI Go to sub group
33135 - EL FREN KUMANDASI Go to sub group
33136 - FREN TESISATI TESPIT ELEMANLARI Go to sub group
381 - MEKANIK AKSAM MUHAFAZALARI Go to group
38115 - SASI MUHAFAZASI Go to sub group
412 - DIREKSIYON SISTEMI Go to group
41201 - DIREKSIYON KUMANDASI Go to sub group
41207 - SERVO DIREKSIYON KUMANDASI Go to sub group
41208 - SERVO DIREKSIYON POMPASI Go to sub group
443 - TEKERLEK VE SUSPANSIYON SISTEMI Go to group
44301 - ON SUSPANSIYON Go to sub group
44305 - ARKA SUSPANSIYON Go to sub group
44316 - TEKERLEKLER Go to sub group
44321 - ARKA AKS PARCASI Go to sub group
501 - KLİMA Go to group
50101 - KALORIFER TESISATI VE VANTILATORU Go to sub group
50104 - KLIMA KOMPRESORU Go to sub group
551 - MOTOR ATESLEME SISTEMI Go to group
55101 - MOTOR ATESLEME SISTEMI Go to sub group
55102 - ATESLEME UNITESI Go to sub group
552 - MARS SISTEMI Go to group
55201 - MARS SISTEMI Go to sub group
55202 - KONTAK ANAHTARI Go to sub group
553 - SARJ SISTEMI Go to group
55300 - AKU Go to sub group
55301 - ALTERNATOR AND MOUNTING Go to sub group
554 - AYDINLATMA SISTEMI Go to group
55401 - DIS AYDINLATMA Go to sub group
55402 - IC AYDINLATMA Go to sub group
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI Go to group
55501 - SINYAL UNITESI VE ELEMANLARI Go to sub group
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER Go to sub group
55503 - KUMANDA DUGMELERI Go to sub group
55508 - HAVA YASTIGI TERTIBATI Go to sub group
55510 - GOSTERGELER Go to sub group
55514 - ON CAM VE FAR YIKAMA Go to sub group
55521 - RADYO SISTEMI Go to sub group
55523 - ON BOLUM KABLO TESISATI Go to sub group
55524 - ORTA BOLUM KABLO TESISATI Go to sub group
55525 - ARKA BOLUM KABLO TESISATI Go to sub group
55526 - ILAVE KABLO TESISATI Go to sub group
55527 - KABLO TESISATI TESPIT ELEMANLARI Go to sub group
681 - AVADANLIK Go to group
68101 - AVADANLIK Go to sub group
700 - KAROSERI VE KAPORTA PARCALARI Go to group
70001 - GOVDE Go to sub group
70002 - GOVDE,ON ISKELET Go to sub group
70003 - GOVDE,ORTA ISKELET Go to sub group
70006 - TABAN SACI Go to sub group
70018 - GOVDE,ON KAPLAMALAR Go to sub group
70019 - GOVDE,ORTA KAPLAMALAR Go to sub group
701 - PANELLER VE CAMLAR Go to group
70101 - MOTOR KAPUTU Go to sub group
70122 - TAVAN PENCERESI Go to sub group
70129 - ON KAPILAR Go to sub group
70133 - ON KAPI IC PANELI Go to sub group
70134 - AKSESUARLAR,ON KAPI IC PANELI ICIN Go to sub group
70148 - BESINCI KAPI Go to sub group
70155 - ON CAM Go to sub group
70156 - YAN CAMLAR Go to sub group
70158 - ARKA CAM Go to sub group
705 - IC TRIM PARCALARI Go to group
70502 - ON GOGUS VE PARCALARI Go to sub group
70504 - ON GOGUS (KONSOL) Go to sub group
70521 - HALILAR Go to sub group
70522 - IZALASYON VE SUNGERLER Go to sub group
70523 - IC KAPLAMALAR Go to sub group
70524 - IC PANEL AKSESUARLARI Go to sub group
70525 - AKSESUARLAR VE DIGER ELEMANLAR Go to sub group
70527 - EMNIYET KEMERLERI Go to sub group
70528 - STEPNE SISTEMI Go to sub group
706 - KOLTUKLAR Go to group
70601 - ON KOLTUKLAR Go to sub group
70605 - ON KOLTUK KIZAKLARI Go to sub group
70606 - ON KOLTUK KILIFLARI Go to sub group
70613 - REAR SEAT Go to sub group
70615 - REAR SEAT LINING Go to sub group
707 - DIS TRIM PARCALARI Go to group
70712 - DIS TRIM PARCALARI Go to sub group
70715 - LOGOLAR, YAZILAR Go to sub group
70717 - HAVA DAGITICILAR VE CESITLI KAPAKLAR Go to sub group
70722 - RADYATOR PANJURU Go to sub group
70723 - SİPERLER Go to sub group
70726 - ON TAMPON Go to sub group
70727 - ARKA TAMPON Go to sub group
70732 - DIS TRIM PARCALARI Go to sub group
70740 - DIS DIKIZ AYNASI Go to sub group
70743 - DOKUMANTASYON Go to sub group
70750 - UYARI VE TAVSİYE ETİKETLERİ Go to sub group
PKP 1250 16V EURO5+EOBD JTD TREKKING 278115301 Go to catalogue
PKP 1250 16V EURO5+EOBD JTD WORKING 278135301 Go to catalogue
PKPDC 1250 16V EURO5+EOBD JTD ADVENTURE 278225301 Go to catalogue
PKPDC 1250 16V EURO5+EOBD JTD TREKKING 278215301 Go to catalogue
PKPDCL 1250 16V EURO5+EOBD JTD ADVENTURE 278325301 Go to catalogue
PKPDCL 1250 16V EURO5+EOBD JTD WORKING 278335301 Go to catalogue
ModificationDescriptionActivations
13000 TO MANAGE RECONDITIONED VEHICLES DAT 30/06/2012
15358 PROSESİN İYİLEŞTİRİLMESİ İÇİN YENİ KABLOLAR DAT 30/04/2012
15407 YENİ DİREKSİYON KUTUSU DAT 25/05/2012
15466 NEW MOBILITY 2012 DAT 21/02/2013
15524 Yeni kablaj DAT 25/07/2012
15644 Egzoz manifoldu/turbokompresör yeni contası DAT 17/02/2012
16325 YENİ FREN KALİPERLERİ VE YENİ FREN DİSKLERİ DAT 14/06/2011
16326 YENİ ÖN FREN KALİPERLERİ TAKILMIŞTIR DAT 01/03/2012
16727 ADOPTION OF NEW REAR AXLES AND REAR HUBS DAT 08/07/2013
16748 ADOPTION OF NEW REAR BRAKES DAT 19/08/2013
17275 Yeni direksiyon kutusu DAT 01/04/2013
17282 NUOVO LIBRETTO USO E MANUTENZIONE PER CAMBIO DISPLAY DAT 01/05/2013
17323 YENİ ARKA FREN GRUBU TAKILMIŞTIR DAT 02/04/2014
