FIAT OTTIMO (2014-....)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU | Go to group |
10000 - MOTOR | Go to sub group |
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU | Go to sub group |
10003 - MOTOR SÜSPANSİYONU | Go to sub group |
101 - BLOK VE SİLİNDİR KAPAĞI | Go to group |
10101 - BLOK VE SİLİNDİR KAPAĞI | Go to sub group |
10102 - KARTER VE BLOK KAPAKLARI | Go to sub group |
10103 - KRANK MİLİ VE VOLAN | Go to sub group |
10105 - BİYELLER VE PİSTONLAR | Go to sub group |
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI | Go to sub group |
10107 - SÜBAP ZAMANLAMA MEKANİZMASI | Go to sub group |
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) | Go to sub group |
102 - ENJEKSIYON SISTEMI | Go to group |
10200 - YAKIT DEPOSU | Go to sub group |
10201 - YAKIT DEPOSU BORULARI | Go to sub group |
10203 - YAKIT BORULARI TESPIT PARCALARI | Go to sub group |
10222 - GAZ PEDALI KUMANDASI | Go to sub group |
10223 - HAVA FILITRESI VE BORULARI | Go to sub group |
10225 - ENJEKSIYON TESISATI | Go to sub group |
10226 - ENJEKSİYON BESLEME | Go to sub group |
10247 - ISI MUHAFAZA VE BORULAR | Go to sub group |
10252 - ASIRI BESLENME SISTEMI | Go to sub group |
10255 - EMME MANIFOLDU | Go to sub group |
10256 - EGZOZ MANIFOLDU | Go to sub group |
10258 - EGZOZ BORUSU | Go to sub group |
103 - YAGLAMA SISTEMI | Go to group |
10301 - YAGLAMA SISTEMI | Go to sub group |
104 - SOGUTMA SISTEMI | Go to group |
10401 - RADYATOR VE BORULAR | Go to sub group |
10402 - SU POMPASI VE BORULARI | Go to sub group |
10409 - VANTILATOR VE KUMANDASI | Go to sub group |
181 - DEBRIYAJ SISTEMI | Go to group |
18101 - DEBRIYAJ BALATA KUMANDASI | Go to sub group |
18103 - HIDROLIK DEBRIYAJ KUMANDASI | Go to sub group |
18109 - DEBRIYAJ SISTEMI | Go to sub group |
212 - VITES KUTUSU | Go to group |
21200 - VITES KUTUSU | Go to sub group |
21207 - KUTU VE KAPAKLAR | Go to sub group |
21215 - VITES DISLILERI | Go to sub group |
21219 - VITES KUTUSU IC KUMANDALARI | Go to sub group |
21220 - DIFRANSIYEL DISLISI | Go to sub group |
21221 - VITES KUTUSU DIS KUMANDALARI | Go to sub group |
274 - AKS VE AKS MILLERI | Go to group |
27400 - AKS TASIYICI | Go to sub group |
27402 - AKSLAR | Go to sub group |
331 - FREN SISTEMI | Go to group |
33101 - FREN PEDEAL KUMANDASI | Go to sub group |
33102 - HIDROLIK FREN KUMANDASI | Go to sub group |
33117 - ON TEKERLEK FREN GRUBU | Go to sub group |
33125 - ARKA TEKERLEK FRENI | Go to sub group |
33135 - EL FREN KUMANDASI | Go to sub group |
33136 - FREN TESISATI TESPIT ELEMANLARI | Go to sub group |
381 - MEKANIK AKSAM MUHAFAZALARI | Go to group |
38115 - SASI MUHAFAZASI | Go to sub group |
412 - DIREKSIYON SISTEMI | Go to group |
41201 - DIREKSIYON KUMANDASI | Go to sub group |
443 - TEKERLEK VE SUSPANSIYON SISTEMI | Go to group |
44301 - ON SUSPANSIYON | Go to sub group |
44305 - ARKA SUSPANSIYON | Go to sub group |
44316 - TEKERLEKLER | Go to sub group |
44321 - ARKA AKS PARCASI | Go to sub group |
501 - KLİMA | Go to group |
50101 - KALORIFER TESISATI VE VANTILATORU | Go to sub group |
50104 - KLIMA KOMPRESORU | Go to sub group |
551 - MOTOR ATESLEME SISTEMI | Go to group |
55101 - MOTOR ATESLEME SISTEMI | Go to sub group |
552 - MARS SISTEMI | Go to group |
55201 - MARS SISTEMI | Go to sub group |
55202 - KONTAK ANAHTARI | Go to sub group |
553 - SARJ SISTEMI | Go to group |
55300 - AKU | Go to sub group |
55301 - ALTERNATOR AND MOUNTING | Go to sub group |
554 - AYDINLATMA SISTEMI | Go to group |
55401 - DIS AYDINLATMA | Go to sub group |
55402 - IC AYDINLATMA | Go to sub group |
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI | Go to group |
55501 - SINYAL UNITESI VE ELEMANLARI | Go to sub group |
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER | Go to sub group |
55503 - KUMANDA DUGMELERI | Go to sub group |
55508 - HAVA YASTIGI TERTIBATI | Go to sub group |
55510 - GOSTERGELER | Go to sub group |
55514 - ON CAM VE FAR YIKAMA | Go to sub group |
55521 - RADYO SISTEMI | Go to sub group |
55523 - ON BOLUM KABLO TESISATI | Go to sub group |
55524 - ORTA BOLUM KABLO TESISATI | Go to sub group |
55525 - ARKA BOLUM KABLO TESISATI | Go to sub group |
55526 - ILAVE KABLO TESISATI | Go to sub group |
55527 - KABLO TESISATI TESPIT ELEMANLARI | Go to sub group |
681 - AVADANLIK | Go to group |
68101 - AVADANLIK | Go to sub group |
700 - KAROSERI VE KAPORTA PARCALARI | Go to group |
70002 - GOVDE,ON ISKELET | Go to sub group |
70003 - GOVDE,ORTA ISKELET | Go to sub group |
70004 - GOVDE ,ARKA ISKELET | Go to sub group |
70006 - TABAN SACI | Go to sub group |
70018 - GOVDE,ON KAPLAMALAR | Go to sub group |
70019 - GOVDE,ORTA KAPLAMALAR | Go to sub group |
70020 - GOVDE,ARKA KAPLAMALAR | Go to sub group |
701 - PANELLER VE CAMLAR | Go to group |
70101 - MOTOR KAPUTU | Go to sub group |
70122 - TAVAN PENCERESI | Go to sub group |
70129 - ON KAPILAR | Go to sub group |
70133 - ON KAPI IC PANELI | Go to sub group |
70134 - AKSESUARLAR,ON KAPI IC PANELI ICIN | Go to sub group |
70136 - ARKA KAPILAR | Go to sub group |
70140 - ARKA KAPI IC PANELI | Go to sub group |
70141 - AKSESUARLAR,ARKA KAPI IC PANELI ICIN | Go to sub group |
70148 - BESINCI KAPI | Go to sub group |
70155 - ON CAM | Go to sub group |
70156 - YAN CAMLAR | Go to sub group |
70158 - ARKA CAM | Go to sub group |
705 - IC TRIM PARCALARI | Go to group |
70502 - ON GOGUS VE PARCALARI | Go to sub group |
70504 - ON GOGUS (KONSOL) | Go to sub group |
70521 - HALILAR | Go to sub group |
70522 - IZALASYON VE SUNGERLER | Go to sub group |
70523 - IC KAPLAMALAR | Go to sub group |
70525 - AKSESUARLAR VE DIGER ELEMANLAR | Go to sub group |
70526 - BAGAJ IC KAPLAMALARI | Go to sub group |
70527 - EMNIYET KEMERLERI | Go to sub group |
706 - KOLTUKLAR | Go to group |
70601 - ON KOLTUKLAR | Go to sub group |
70606 - ON KOLTUK KILIFLARI | Go to sub group |
70613 - REAR SEAT | Go to sub group |
70615 - REAR SEAT LINING | Go to sub group |
707 - DIS TRIM PARCALARI | Go to group |
70712 - DIS TRIM PARCALARI | Go to sub group |
70715 - LOGOLAR, YAZILAR | Go to sub group |
70717 - HAVA DAGITICILAR VE CESITLI KAPAKLAR | Go to sub group |
70722 - RADYATOR PANJURU | Go to sub group |
70723 - SİPERLER | Go to sub group |
70726 - ON TAMPON | Go to sub group |
70727 - ARKA TAMPON | Go to sub group |
70740 - DIS DIKIZ AYNASI | Go to sub group |
70743 - DOKUMANTASYON | Go to sub group |
70750 - UYARI VE TAVSİYE ETİKETLERİ | Go to sub group |
2V. 1.4 TRB 120CV DDCT CF5 ACTIVE CHINA | 34312D001270 | Go to catalogue |
2V. 1.4 TRB 120CV DDCT CF5 DYNAMIC CHINA | 34322D001270 | Go to catalogue |
2V. 1.4 TRB 120CV MT CF5 ACTIVE CHINA | 34312A001270 | Go to catalogue |
2V. 1.4 TRB 120CV MT CF5 DYNAMIC CHINA | 34322C001270 | Go to catalogue |
2V. 1.4 TRB 150CV DDCT CF5 DYNAMIC CHINA | 34322F001270 | Go to catalogue |
2V. 1.4 TRB 150CV DDCT CF5 EMOTION CHINA | 34332F001270 | Go to catalogue |
2V. 1.4 TRB 150CV DDCT CF5 SP.LX CHINA | 34352F001270 | Go to catalogue |
2V. 1.4 TRB 150CV DDCT CF5 SPORT CHINA | 34342F001270 | Go to catalogue |
Modification | Description | Activations |
16143 | Yeni elektronik ünite takılmıştır | DAT 05/11/2012 |
16173 | Yeni ön koltuk başlıkları | DAT 12/11/2012 |
16187 | SÜS KAPLAMASI | DAT 11/08/2012 |
16243 | TAVAN LAMBA SPORTU ELİMİNE EDİLMİŞTİR | DAT 03/10/2012 |
16260 | YENİ ÖN KOLTUK KILIFLARI | DAT 01/10/2012 |
16277 | YENİ ESNEK BORU | DAT 25/01/2013 |
16362 | Yeni vites kutuları | DAT 29/01/2013 |
16378 | Yeni braket takılmıştır | DAT 10/05/2012 |
16549 | ON TAILGATE MODIFIED SHAPE IN BUMPER AREA. | DAT 08/11/2012 |
16964 | Adoption of new gearbox control device | DAT 10/10/2013 |
17000 | nuova centralina elettronica albero strerzo | DAT 13/12/2013 |
17303 | Nuova autoradio CD MP3 | DAT 13/12/2013 |
17305 | nuova vite speciale supporto batteria | DAT 24/03/2014 |
17306 | Nuovo avvisatore acustico toni bassi | DAT 13/12/2013 |
17312 | nuovo complessivo pedaliera | DAT 17/12/2013 |
17325 | NEW BODY COMPUTER CONTROL | DAT 14/12/2013 |
17362 | NUOVA PLAFONIERA BAULE | DAT 25/07/2013 |
17382 | Adozione nuovi tasselli per sospensione posteriore | DAT 23/12/2013 |
17400 | ADOZIONE NUOVO CONTROL MODEL BODY COMPUTER | DAT 12/02/2014 |
17421 | ADOZIONE NUOVO CAPPUCCIO AMMORTIZZATORE | DAT 07/03/2014 |
