FIAT FREEMONT (2011-....)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU | Go to group |
10000 - MOTOR | Go to sub group |
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU | Go to sub group |
10003 - MOTOR SÜSPANSİYONU | Go to sub group |
101 - BLOK VE SİLİNDİR KAPAĞI | Go to group |
10101 - BLOK VE SİLİNDİR KAPAĞI | Go to sub group |
10102 - KARTER VE BLOK KAPAKLARI | Go to sub group |
10103 - KRANK MİLİ VE VOLAN | Go to sub group |
10105 - BİYELLER VE PİSTONLAR | Go to sub group |
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI | Go to sub group |
10107 - SÜBAP ZAMANLAMA MEKANİZMASI | Go to sub group |
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) | Go to sub group |
102 - ENJEKSIYON SISTEMI | Go to group |
10200 - YAKIT DEPOSU | Go to sub group |
10201 - YAKIT DEPOSU BORULARI | Go to sub group |
10222 - GAZ PEDALI KUMANDASI | Go to sub group |
10223 - HAVA FILITRESI VE BORULARI | Go to sub group |
10225 - ENJEKSIYON TESISATI | Go to sub group |
10226 - ENJEKSİYON BESLEME | Go to sub group |
10247 - ISI MUHAFAZA VE BORULAR | Go to sub group |
10252 - ASIRI BESLENME SISTEMI | Go to sub group |
10255 - EMME MANIFOLDU | Go to sub group |
10256 - EGZOZ MANIFOLDU | Go to sub group |
10258 - EGZOZ BORUSU | Go to sub group |
10259 - EGZOZ EMISYON KONTROL SISTEMI | Go to sub group |
10260 - HAVA KIRLILIK ONLEME SISTEMI | Go to sub group |
103 - YAGLAMA SISTEMI | Go to group |
10301 - YAGLAMA SISTEMI | Go to sub group |
104 - SOGUTMA SISTEMI | Go to group |
10401 - RADYATOR VE BORULAR | Go to sub group |
10402 - SU POMPASI VE BORULARI | Go to sub group |
181 - DEBRIYAJ SISTEMI | Go to group |
18101 - DEBRIYAJ BALATA KUMANDASI | Go to sub group |
18103 - HIDROLIK DEBRIYAJ KUMANDASI | Go to sub group |
18109 - DEBRIYAJ SISTEMI | Go to sub group |
212 - VITES KUTUSU | Go to group |
21200 - VITES KUTUSU | Go to sub group |
21201 - OTOMATIK VITES KUTUSU | Go to sub group |
21207 - KUTU VE KAPAKLAR | Go to sub group |
21215 - VITES DISLILERI | Go to sub group |
21219 - VITES KUTUSU IC KUMANDALARI | Go to sub group |
21220 - DIFRANSIYEL DISLISI | Go to sub group |
21221 - VITES KUTUSU DIS KUMANDALARI | Go to sub group |
21231 - OTOMATIK VITES SOGUTUCU SISTEMI | Go to sub group |
243 - MILLER VE MAFSALLAR | Go to group |
24301 - SAFT | Go to sub group |
274 - AKS VE AKS MILLERI | Go to group |
27402 - AKSLAR | Go to sub group |
27403 - ÖN KÖPRÜ VE GÜÇ ALICISI | Go to sub group |
27404 - ARKA KÖPRÜ DİFERANSİYEL YARIM AKSLARI (4X4) | Go to sub group |
331 - FREN SISTEMI | Go to group |
33101 - FREN PEDEAL KUMANDASI | Go to sub group |
33102 - HIDROLIK FREN KUMANDASI | Go to sub group |
33109 - FREN BASINC TESISATI | Go to sub group |
33117 - ON TEKERLEK FREN GRUBU | Go to sub group |
33125 - ARKA TEKERLEK FRENI | Go to sub group |
33135 - EL FREN KUMANDASI | Go to sub group |
381 - MEKANIK AKSAM MUHAFAZALARI | Go to group |
38115 - SASI MUHAFAZASI | Go to sub group |
412 - DIREKSIYON SISTEMI | Go to group |
41201 - DIREKSIYON KUMANDASI | Go to sub group |
41207 - SERVO DIREKSIYON KUMANDASI | Go to sub group |
41208 - SERVO DIREKSIYON POMPASI | Go to sub group |
443 - TEKERLEK VE SUSPANSIYON SISTEMI | Go to group |
44301 - ON SUSPANSIYON | Go to sub group |
44305 - ARKA SUSPANSIYON | Go to sub group |
44316 - TEKERLEKLER | Go to sub group |
501 - KLİMA | Go to group |
50101 - KALORIFER TESISATI VE VANTILATORU | Go to sub group |
50104 - KLIMA KOMPRESORU | Go to sub group |
551 - MOTOR ATESLEME SISTEMI | Go to group |
55101 - MOTOR ATESLEME SISTEMI | Go to sub group |
552 - MARS SISTEMI | Go to group |
55201 - MARS SISTEMI | Go to sub group |
55202 - KONTAK ANAHTARI | Go to sub group |
553 - SARJ SISTEMI | Go to group |
55300 - AKU | Go to sub group |
55301 - ALTERNATOR AND MOUNTING | Go to sub group |
554 - AYDINLATMA SISTEMI | Go to group |
55401 - DIS AYDINLATMA | Go to sub group |
55402 - IC AYDINLATMA | Go to sub group |
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI | Go to group |
55501 - SINYAL UNITESI VE ELEMANLARI | Go to sub group |
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER | Go to sub group |
55503 - KUMANDA DUGMELERI | Go to sub group |
55508 - HAVA YASTIGI TERTIBATI | Go to sub group |
55510 - GOSTERGELER | Go to sub group |
55514 - ON CAM VE FAR YIKAMA | Go to sub group |
55518 - ALARM SISTEMI | Go to sub group |
55521 - RADYO SISTEMI | Go to sub group |
55523 - ON BOLUM KABLO TESISATI | Go to sub group |
55524 - ORTA BOLUM KABLO TESISATI | Go to sub group |
55525 - ARKA BOLUM KABLO TESISATI | Go to sub group |
55526 - ILAVE KABLO TESISATI | Go to sub group |
55527 - KABLO TESISATI TESPIT ELEMANLARI | Go to sub group |
55528 - KABLO DEMETİ SOKETLERİ | Go to sub group |
55530 - DEVLET ARAÇLARI TERTİBATLARI | Go to sub group |
55534 - KAPI KABLO DEMETİ | Go to sub group |
681 - AVADANLIK | Go to group |
68101 - AVADANLIK | Go to sub group |
700 - KAROSERI VE KAPORTA PARCALARI | Go to group |
70002 - GOVDE,ON ISKELET | Go to sub group |
70004 - GOVDE ,ARKA ISKELET | Go to sub group |
70006 - TABAN SACI | Go to sub group |
70018 - GOVDE,ON KAPLAMALAR | Go to sub group |
70019 - GOVDE,ORTA KAPLAMALAR | Go to sub group |
701 - PANELLER VE CAMLAR | Go to group |
70101 - MOTOR KAPUTU | Go to sub group |
70122 - TAVAN PENCERESI | Go to sub group |
70129 - ON KAPILAR | Go to sub group |
70133 - ON KAPI IC PANELI | Go to sub group |
70136 - ARKA KAPILAR | Go to sub group |
70140 - ARKA KAPI IC PANELI | Go to sub group |
70148 - BESINCI KAPI | Go to sub group |
70150 - CAMLAR | Go to sub group |
705 - IC TRIM PARCALARI | Go to group |
70502 - ON GOGUS VE PARCALARI | Go to sub group |
70504 - ON GOGUS (KONSOL) | Go to sub group |
70521 - HALILAR | Go to sub group |
70522 - IZALASYON VE SUNGERLER | Go to sub group |
70523 - IC KAPLAMALAR | Go to sub group |
70525 - AKSESUARLAR VE DIGER ELEMANLAR | Go to sub group |
70526 - BAGAJ IC KAPLAMALARI | Go to sub group |
70527 - EMNIYET KEMERLERI | Go to sub group |
70532 - CONTAINER | Go to sub group |
706 - KOLTUKLAR | Go to group |
70601 - ON KOLTUKLAR | Go to sub group |
70613 - REAR SEAT | Go to sub group |
70620 - KOLTUK BAĞLANTI ELEMANLARI | Go to sub group |
707 - DIS TRIM PARCALARI | Go to group |
70712 - DIS TRIM PARCALARI | Go to sub group |
70715 - LOGOLAR, YAZILAR | Go to sub group |
70717 - HAVA DAGITICILAR VE CESITLI KAPAKLAR | Go to sub group |
70722 - RADYATOR PANJURU | Go to sub group |
70723 - SİPERLER | Go to sub group |
70726 - ON TAMPON | Go to sub group |
70727 - ARKA TAMPON | Go to sub group |
70740 - DIS DIKIZ AYNASI | Go to sub group |
70743 - DOKUMANTASYON | Go to sub group |
70750 - UYARI VE TAVSİYE ETİKETLERİ | Go to sub group |
2.0 DS 140HP MT6 FWD P.AVENUE | 345T56201000 | Go to catalogue |
2.0 DS 170HP AT6 AWD P.AVENUE | 345S36201000 | Go to catalogue |
2.0DS 140HP MT6 ALL-INCLUDED | 345O00001000 | Go to catalogue |
2.0DS 140HP MT6 ALL-INCLUDED | 345O00051870 | Go to catalogue |
2.0DS 140HP MT6 FREEMONT | 345J80001000 | Go to catalogue |
2.0DS 140HP MT6 FREEMONT | 345J80051870 | Go to catalogue |
2.0DS 140HP MT6 URBAN | 345OA0001000 | Go to catalogue |
2.0DS 140HP MT6 URBAN | 345OA0051870 | Go to catalogue |
2.0DS 170HP AT6 ALL-INCLUDED | 345N50001000 | Go to catalogue |
2.0DS 170HP AT6 URBAN | 345N40001000 | Go to catalogue |
2.0DS 170HP MT6 ALL-INCLUDED | 345OC0051870 | Go to catalogue |
2.0DS 170HP MT6 ALL-INCLUDED | 345OC0001000 | Go to catalogue |
2.0DS 170HP MT6 FREEMONT | 345J90001000 | Go to catalogue |
2.0DS 170HP MT6 FREEMONT | 345J90051870 | Go to catalogue |
2.0DS 170HP MT6 URBAN | 345OB0001000 | Go to catalogue |
2.0DS 170HP MT6 URBAN | 345OB0051870 | Go to catalogue |
2.4 BZ AT6 FWD P.AVENUE | 345T38201000 | Go to catalogue |
3.6BZ 267HP AT6 ALL-INCLUDED | 345N72001000 | Go to catalogue |
3.6BZ 267HP AT6 URBAN | 345N62001000 | Go to catalogue |
BLACK CODE 2.0 DS 140HP MT6 FWD | 345T5B301000 | Go to catalogue |
BLACK CODE 2.0 DS 170HP AT6 AWD | 345S3B301000 | Go to catalogue |
BLACK CODE NAVI 2.4 BZ 170HP AT6 FWD | 345O9D301270 | Go to catalogue |
BLACK ODE 3.6 BZ 280HP AT6 AWD | 345S4C301000 | Go to catalogue |
BZ 140 HP | 345S42101000 | Go to catalogue |
BZ 4SPEED AUTO | 345JD3101552 | Go to catalogue |
BZ 4SPEED AUTO | 345OC3101552 | Go to catalogue |
BZ 4SPEED AUTO | 345OE3101552 | Go to catalogue |
BZ 4SPEED AUTO | 345JB3101552 | Go to catalogue |
BZ AUTO 170HP | 345J61101270 | Go to catalogue |
CROSS 2.0 DS 140HP MT6 FWD | 345500301000 | Go to catalogue |
CROSS 2.0 DS 170HP AT6 AWD | 345810301000 | Go to catalogue |
CROSS 2.0 DS 170HP MT6 FWD | 345504301000 | Go to catalogue |
DS 140HP | 345T50101000 | Go to catalogue |
DS 170HP | 345T54101000 | Go to catalogue |
DS AUTO 170 HP | 345O91101270 | Go to catalogue |
DS AUTO 170HP | 345S30101000 | Go to catalogue |
DS AUTO 170HP | 345N00101000 | Go to catalogue |
DS AUTO 170HP | 345I20101000 | Go to catalogue |
FREEMONT 2.0 DS 140HP MT6 FWD | 345J80301000 | Go to catalogue |
FREEMONT 2.0 DS 170HP AT6 AWD | 345I20301000 | Go to catalogue |
FREEMONT 2.0 DS 170HP MT6 FWD | 345J84301000 | Go to catalogue |
FREEMONT 2.4 BZ AT6 FWD | 345J11301000 | Go to catalogue |
FREEMONT BZ FWD | 345J61201270 | Go to catalogue |
FREMONT 2.0 DS 140HP MT6 | 345J80101000 | Go to catalogue |
FREMONT 2.0 DS 140HP MT6 | 345J80201000 | Go to catalogue |
FREMONT 2.0 DS 170HP AT6 AWD | 345I29201000 | Go to catalogue |
FREMONT 2.0 DS 170HP AT6 AWD | 345I20201000 | Go to catalogue |
FREMONT 2.0 DS 170HP MT6 | 345J84101000 | Go to catalogue |
FREMONT 2.0 DS 170HP MT6 | 345J84201000 | Go to catalogue |
FREMONT 2.4 BZ 170HP AT6 FWD | 345J61301270 | Go to catalogue |
FREMONT 2.4 BZ AT6 FWD | 345J11201000 | Go to catalogue |
LOUNGE 2.0 DS 140HP MT6 | 345T50201000 | Go to catalogue |
LOUNGE 2.0 DS 140HP MT6 FWD | 345T50301000 | Go to catalogue |
LOUNGE 2.0 DS 170 HP AT6 AWD | 345S30201000 | Go to catalogue |
LOUNGE 2.0 DS 170HP AT6 AWD | 345S30301000 | Go to catalogue |
LOUNGE 2.0 DS 170HP MT6 | 345T54201000 | Go to catalogue |
LOUNGE 2.0 DS 170HP MT6 FWD | 345T54301000 | Go to catalogue |
LOUNGE 2.4 BZ AT6 FWD | 345T31201000 | Go to catalogue |
LOUNGE 2.4 BZ AT6 FWD | 345T31301000 | Go to catalogue |
LOUNGE 3.6 BZ 276HP AT6 AWD | 345S02301270 | Go to catalogue |
LOUNGE 3.6 BZ 280 HP AT6 AWD | 345S42201000 | Go to catalogue |
LOUNGE 3.6 BZ 280HP AT6 AWD | 345S42301000 | Go to catalogue |
LOUNGE BZ AWD | 345S02201270 | Go to catalogue |
POLIZIA 2.0 DS 170HP AT6 AWD | 345I29301000 | Go to catalogue |
URBAN 2.0 DS 140HP MT6 | 345OA0201000 | Go to catalogue |
URBAN 2.0 DS 140HP MT6 | 345OA0101000 | Go to catalogue |
URBAN 2.0 DS 140HP MT6 FWD | 345OA0301000 | Go to catalogue |
URBAN 2.0 DS 170 HP AT6 AWD | 345N00201000 | Go to catalogue |
URBAN 2.0 DS 170HP AT6 AWD | 345N00301000 | Go to catalogue |
URBAN 2.0 DS 170HP MT6 | 345OA4101000 | Go to catalogue |
URBAN 2.0 DS 170HP MT6 | 345OA4201000 | Go to catalogue |
URBAN 2.0 DS 170HP MT6 FWD | 345OA4301000 | Go to catalogue |
URBAN 2.4 BZ 170HP AT6 FWD | 345O91301270 | Go to catalogue |
URBAN 2.4 BZ AT6 FWD | 345O21201000 | Go to catalogue |
URBAN 2.4 BZ AT6 FWD | 345O21301000 | Go to catalogue |
URBAN 3.6 BZ 276HP AT6 | 345N12101000 | Go to catalogue |
URBAN 3.6 BZ 280 HP AT6 AWD | 345N12201000 | Go to catalogue |
URBAN 3.6 BZ 280HP AT6 AWD | 345N12301000 | Go to catalogue |
URBAN BZ FWD | 345O91201270 | Go to catalogue |
URBAN NAVI 2.4 BZ 170HP AT6 FWD | 345O9A301270 | Go to catalogue |
URBAN NAVI BZ FWD | 345O95201270 | Go to catalogue |
URBAN NAVI BZ FWD | 345O9A201270 | Go to catalogue |
Modification | Description | Activations |
13000 | TO MANAGE RECONDITIONED VEHICLES | DAT 30/06/2012 |
15005 | YENİ ENJEKSİYON POMPASI | DAT 23/03/2011 |
15040 | Yeni motor volanı | DAT 17/04/2011 |
15104 | YENİ SENKROMENÇ HALKALARI VE MANŞONLAR | DAT 17/04/2012 |
15134 | YENİ TURBOKOMPRESÖR | MOT 7070055 |
15149 | YENİ MOTOR SPORTU | DAT 08/02/2011 |
15703 | Yeni LUM | DAT 01/03/2012 |
15752 | Yeni yağ pompası | DAT 20/02/2012 |
15837 | ARKA FREN YENİ YAY KİTİ VE FREN BALATALARI TAKILMIŞTIR | DAT 06/03/2012 |
15851 | Beşinci kapı (bagaj kapağı) yeni kolu,plaka lambası,kablo takılmıştır | DAT 26/11/2011 |
15924 | YENİ ENJEKTÖR BRAKETİ | MOT 6608997 |
15941 | DUALOGIC VİTES YENİ EL KİTABI EKİ | DAT 16/07/2012 |
15944 | Freemont termostatları | DAT 06/04/2012 |
16008 | YENİ YEDEK LASTİK | DAT 16/07/2012 |
16009 | Yeni direksiyon yağ radyatörü | DAT 07/05/2012 |
16027 | Yeni motor volanı | DAT 05/09/2012 |
16275 | Yeni vites kutuları | DAT 07/01/2013 |
16588 | Adoption of new 2nd speed gear | DAT 30/09/2013 |
16668 | NEW WIPER ARMS/BLADES | DAT 03/01/2013 |
16761 | YENİ TURBOKOMPRESÖR | DAT 27/11/2013 |
16771 | New cylinder head complete with valves for new supplier | DAT 24/07/2013 |
16882 | YENİ MOTOR VOLANI | DAT 15/12/2013 |
16890 | YENİ TURBOKOMPRESÖR | DAT 25/02/2014 DAT 03/03/2014 |
16893 | YENİ YAĞ DEŞARJ BORUSU | DAT 27/11/2013 |
