FIAT SEDICI MY 2012 (2012-2014)
Select the main category from the menu or directly from the car map.
100 - MOTOR VE MOTOR SUSPANSIYON GRUBU Go to group
10000 - MOTOR Go to sub group
10002 - SÜSPANSİYON MOTOR VİT.KUTUSU BAĞLANTILARI GRUBU Go to sub group
10003 - MOTOR SÜSPANSİYONU Go to sub group
101 - BLOK VE SİLİNDİR KAPAĞI Go to group
10101 - BLOK VE SİLİNDİR KAPAĞI Go to sub group
10102 - KARTER VE BLOK KAPAKLARI Go to sub group
10103 - KRANK MİLİ VE VOLAN Go to sub group
10105 - BİYELLER VE PİSTONLAR Go to sub group
10106 - SÜBAP ZAMANLAMA MEKANİZMA KUMANDASI Go to sub group
10107 - SÜBAP ZAMANLAMA MEKANİZMASI Go to sub group
10115 - ÇEŞİTLİ KUMANDALAR (KAYIŞLAR VE KASNAKLAR) Go to sub group
102 - ENJEKSIYON SISTEMI Go to group
10200 - YAKIT DEPOSU Go to sub group
10201 - YAKIT DEPOSU BORULARI Go to sub group
10222 - GAZ PEDALI KUMANDASI Go to sub group
10223 - HAVA FILITRESI VE BORULARI Go to sub group
10225 - ENJEKSIYON TESISATI Go to sub group
10226 - ENJEKSİYON BESLEME Go to sub group
10247 - ISI MUHAFAZA VE BORULAR Go to sub group
10252 - ASIRI BESLENME SISTEMI Go to sub group
10255 - EMME MANIFOLDU Go to sub group
10256 - EGZOZ MANIFOLDU Go to sub group
10258 - EGZOZ BORUSU Go to sub group
10259 - EGZOZ EMISYON KONTROL SISTEMI Go to sub group
10260 - HAVA KIRLILIK ONLEME SISTEMI Go to sub group
103 - YAGLAMA SISTEMI Go to group
10301 - YAGLAMA SISTEMI Go to sub group
104 - SOGUTMA SISTEMI Go to group
10401 - RADYATOR VE BORULAR Go to sub group
10402 - SU POMPASI VE BORULARI Go to sub group
10409 - VANTILATOR VE KUMANDASI Go to sub group
181 - DEBRIYAJ SISTEMI Go to group
18103 - HIDROLIK DEBRIYAJ KUMANDASI Go to sub group
18109 - DEBRIYAJ SISTEMI Go to sub group
212 - VITES KUTUSU Go to group
21200 - VITES KUTUSU Go to sub group
21201 - OTOMATIK VITES KUTUSU Go to sub group
21207 - KUTU VE KAPAKLAR Go to sub group
21215 - VITES DISLILERI Go to sub group
21219 - VITES KUTUSU IC KUMANDALARI Go to sub group
21220 - DIFRANSIYEL DISLISI Go to sub group
21221 - VITES KUTUSU DIS KUMANDALARI Go to sub group
243 - MILLER VE MAFSALLAR Go to group
24301 - SAFT Go to sub group
274 - AKS VE AKS MILLERI Go to group
27402 - AKSLAR Go to sub group
27403 - ÖN KÖPRÜ VE GÜÇ ALICISI Go to sub group
27404 - ARKA KÖPRÜ DİFERANSİYEL YARIM AKSLARI (4X4) Go to sub group
27408 - DİŞLİ KUTUSU VE ARKA KÖPRÜ DİFERANSİYELİ (4X4) Go to sub group
331 - FREN SISTEMI Go to group
33101 - FREN PEDEAL KUMANDASI Go to sub group
33102 - HIDROLIK FREN KUMANDASI Go to sub group
33109 - FREN BASINC TESISATI Go to sub group
33117 - ON TEKERLEK FREN GRUBU Go to sub group
33125 - ARKA TEKERLEK FRENI Go to sub group
33135 - EL FREN KUMANDASI Go to sub group
381 - MEKANIK AKSAM MUHAFAZALARI Go to group
38115 - SASI MUHAFAZASI Go to sub group
412 - DIREKSIYON SISTEMI Go to group
41201 - DIREKSIYON KUMANDASI Go to sub group
443 - TEKERLEK VE SUSPANSIYON SISTEMI Go to group
44301 - ON SUSPANSIYON Go to sub group
44305 - ARKA SUSPANSIYON Go to sub group
44316 - TEKERLEKLER Go to sub group
44321 - ARKA AKS PARCASI Go to sub group
501 - KLİMA Go to group
50101 - KALORIFER TESISATI VE VANTILATORU Go to sub group
50104 - KLIMA KOMPRESORU Go to sub group
551 - MOTOR ATESLEME SISTEMI Go to group
55101 - MOTOR ATESLEME SISTEMI Go to sub group
55102 - ATESLEME UNITESI Go to sub group
552 - MARS SISTEMI Go to group
55201 - MARS SISTEMI Go to sub group
55202 - KONTAK ANAHTARI Go to sub group
553 - SARJ SISTEMI Go to group
55300 - AKU Go to sub group
55301 - ALTERNATOR AND MOUNTING Go to sub group
554 - AYDINLATMA SISTEMI Go to group
55401 - DIS AYDINLATMA Go to sub group
55402 - IC AYDINLATMA Go to sub group
555 - ELEKTRIKLI KUMANDALAR VE PARCALARI Go to group
55501 - SINYAL UNITESI VE ELEMANLARI Go to sub group
55502 - SIGORTA KUTUSU IC BAGLANTILAR VE ROLELER Go to sub group
55503 - KUMANDA DUGMELERI Go to sub group
55508 - HAVA YASTIGI TERTIBATI Go to sub group
55510 - GOSTERGELER Go to sub group
55514 - ON CAM VE FAR YIKAMA Go to sub group
55521 - RADYO SISTEMI Go to sub group
55523 - ON BOLUM KABLO TESISATI Go to sub group
55524 - ORTA BOLUM KABLO TESISATI Go to sub group
55525 - ARKA BOLUM KABLO TESISATI Go to sub group
55526 - ILAVE KABLO TESISATI Go to sub group
55527 - KABLO TESISATI TESPIT ELEMANLARI Go to sub group
681 - AVADANLIK Go to group
68101 - AVADANLIK Go to sub group
700 - KAROSERI VE KAPORTA PARCALARI Go to group
70002 - GOVDE,ON ISKELET Go to sub group
70003 - GOVDE,ORTA ISKELET Go to sub group
70004 - GOVDE ,ARKA ISKELET Go to sub group
70006 - TABAN SACI Go to sub group
70018 - GOVDE,ON KAPLAMALAR Go to sub group
70019 - GOVDE,ORTA KAPLAMALAR Go to sub group
70020 - GOVDE,ARKA KAPLAMALAR Go to sub group
701 - PANELLER VE CAMLAR Go to group
70101 - MOTOR KAPUTU Go to sub group
70129 - ON KAPILAR Go to sub group
70133 - ON KAPI IC PANELI Go to sub group
70136 - ARKA KAPILAR Go to sub group
70140 - ARKA KAPI IC PANELI Go to sub group
70148 - BESINCI KAPI Go to sub group
70155 - ON CAM Go to sub group
70156 - YAN CAMLAR Go to sub group
705 - IC TRIM PARCALARI Go to group
70502 - ON GOGUS VE PARCALARI Go to sub group
70504 - ON GOGUS (KONSOL) Go to sub group
70521 - HALILAR Go to sub group
70522 - IZALASYON VE SUNGERLER Go to sub group
70523 - IC KAPLAMALAR Go to sub group
70525 - AKSESUARLAR VE DIGER ELEMANLAR Go to sub group
70526 - BAGAJ IC KAPLAMALARI Go to sub group
70527 - EMNIYET KEMERLERI Go to sub group
706 - KOLTUKLAR Go to group
70601 - ON KOLTUKLAR Go to sub group
70605 - ON KOLTUK KIZAKLARI Go to sub group
70606 - ON KOLTUK KILIFLARI Go to sub group
70613 - REAR SEAT Go to sub group
70615 - REAR SEAT LINING Go to sub group
707 - DIS TRIM PARCALARI Go to group
70712 - DIS TRIM PARCALARI Go to sub group
70715 - LOGOLAR, YAZILAR Go to sub group
70717 - HAVA DAGITICILAR VE CESITLI KAPAKLAR Go to sub group
70722 - RADYATOR PANJURU Go to sub group
70723 - SİPERLER Go to sub group
70726 - ON TAMPON Go to sub group
70727 - ARKA TAMPON Go to sub group
70732 - DIS TRIM PARCALARI Go to sub group
70740 - DIS DIKIZ AYNASI Go to sub group
70743 - DOKUMANTASYON Go to sub group
70750 - UYARI VE TAVSİYE ETİKETLERİ Go to sub group
1.6 BZ 16V 4X2 ACTIVE CF5 189.611.3.0 Go to catalogue
1.6 BZ 16V 4X2 DYNAMIC CF4 189.631.3.0 Go to catalogue
1.6 BZ 16V 4X2 DYNAMIC CF5 189.111.3.0 Go to catalogue
1.6 BZ 16V 4X2 DYNAMIC CF5 C.A. 189.231.3.0 Go to catalogue
1.6 BZ 16V 4X2 EMOTION CF4 189.731.3.0 Go to catalogue
1.6 BZ 16V 4X2 EMOTION CF5 189.511.3.0 Go to catalogue
1.6 BZ 16V 4X2 EMOTION CF5 C.A. 189.331.3.0 Go to catalogue
1.6 BZ 16V 4X4 ACTIVE CF5 189.711.3.0 Go to catalogue
1.6 BZ 16V 4X4 DYNAMIC CF5 189.211.3.0 Go to catalogue
1.6 BZ 16V 4X4 EMOTION CF4 189.911.3.0 Go to catalogue
1.6 BZ 16V 4X4 EMOTION CF5 189.311.3.0 Go to catalogue
1.6 BZ 16V 4X4 LUXURY CF5 189.411.3.0 Go to catalogue
1.6 BZ 16V DYNAMIC 4X2 CF5 C.A. - RUSSIA 189.632.4.0 Go to catalogue
1.6 BZ 16V DYNAMIC 4X2 CF5+ 189.112.4.0 Go to catalogue
1.6 BZ 16V DYNAMIC 4X4 CF5+ 189.212.4.0 Go to catalogue
1.6 BZ 16V EMOTION 4X2 CF5 C.A. - RUSSIA 189.732.4.0 Go to catalogue
1.6 BZ 16V EMOTION 4X2 CF5+ 189.512.4.0 Go to catalogue
1.6 BZ 16V EMOTION 4X4 CF5 - RUSSIA 189.912.4.0 Go to catalogue
1.6 BZ 16V EMOTION 4X4 CF5+ 189.312.4.0 Go to catalogue
2.0 DS 4X2 DYNAMIC CF5 189.116.3.0 Go to catalogue
2.0 DS 4X2 EMOTION CF5 189.516.3.0 Go to catalogue
2.0 DS 4X4 DYNAMIC CF5 189.216.3.0 Go to catalogue
2.0 DS 4X4 EMOTION CF5 189.316.3.0 Go to catalogue
2.0 DS 4X4 LUXURY CF5 189.416.3.0 Go to catalogue
ModificationDescriptionActivations
13000 TO MANAGE RECONDITIONED VEHICLES DAT 30/06/2012
15397 YENİ HARİTA GÜNCELLEŞTİRMESİ DAT 01/06/2012
15419 YENİ DİREKSİYON KUTUSU DAT 01/12/2011
15424 YENİ DPF SENSÖRÜ DAT 01/02/2011
15428 YENİ ANA SİLİNDİR DAT 01/08/2012
15449 YENİ ŞASE DAT 01/06/2012
15455 NAVIGATORLÜ YENİ RADYO DAT 01/01/2012
15456 YENİ ESNEK BORU DAT 01/06/2012
15457 YENİ ZİNCİR GERDİRİCİ DAT 01/10/2012
15458 YENİ TEKER İÇ YUVASI DAT 01/11/2012
15459 YENİ DURDURMA ÇATALI DAT 01/10/2012
15460 YENİ EMNİYET KİLİDİ DAT 01/12/2012
15461 YENİ YAĞ POMPASI DAT 01/11/2012
15462 YENİ VİTES DIŞ KUMANDASI DAT 24/01/2013
15463 YENİ VİTES GÖBEĞİ DAT 01/06/2012
15464 YENİ BASINÇ SENSÖRÜ DAT 01/05/2013
15466 NEW MOBILITY 2012 DAT 21/02/2013
15474 YENİ DİŞLİ DAT 01/05/2013
15475 NEW SATELLITE CARRIER DAT 01/04/2013
15919 YENİ ENJEKTÖR DESTEK BRAKETİ DAT 19/06/2012
16882 YENİ MOTOR VOLANI MOT 7020150
16893 YENİ YAĞ DEŞARJ BORUSU DAT 27/11/2013
17153 NUOVO PATTINO CATENA DI DISTRIBUZIONE DAT 01/05/2013
17154 NUOVO TAPPO PORTE DAT 01/06/2013
17155 impugnatura per cambio automatico DAT 01/06/2012
17168 cerniere sedili posteriori DAT 01/12/2013
17170 Albero sterzo mecc. (guida sinistra) DAT 01/10/2013
17171 tappo scatola cambio 6m CC2.0 DAT 01/03/2013
17172 martinello DAT 01/12/2013
17176 vite su porte laterali DAT 01/12/2013
17178 Dado su fuso/mozzo posteriore DAT 01/11/2013
17180 Serie pastiglie freno DAT 01/01/2014
17183 Centralina iniezione DAT 01/12/2012
17184 Bobina accensione DAT 01/01/2014
17189 nuovo insieme cavi DAT 01/08/2012
17199 Sostituzione tappo con ripristinato DAT 01/08/2013
17201 Nuovo tappo serbatoio / bocchettone carburante DAT 01/11/2012
17217 nuovo insieme cavi parte posteriore DAT 01/08/2012
17222 Nuovo fuso/mozzo posteriore DAT 01/04/2014
17249 Nuovi air-bag guidatore DAT 01/03/2014
17250 Nuova pompa alimentazione DAT 01/05/2014
17251 Nuovo teleruttore DAT 01/04/2014
17539 nuovo avvisatore acustico DAT 01/05/2014
17540 nuovo termostato DAT 01/04/2014
17542 nuovi semialberi posteriori DAT 01/04/2014
